Looking for 6.4 engine
rrod
As the title states...looking for a 6.4L. After 5 months of my so called mechanic trying to fix my engine and over $3k in parts thrown at it, I'm cutting my losses and looking for a really cheap running 6.4... email text call 954-347-0374
My current engine originally started as a blown oil cooler and has never started since the mechanic worked on the truck that day. After oil cooler - no start. Thought loss of pressure and got new HPFP. Installed and still no start. Went to ford and they couldn't figure it out other then saying new engine. We changed sensors, 2 burned out starters, wire looms around the oil cooler, new injectors and still no start. Truck is building pressure but no start.
pdumont01
CT
New engine for a no start? Be careful buying used 6.4 you may be buying a different problem. Is there any codes
Bustedknuckles
That is absurd. A diesel needs fuel pressure and compression and needs to know when it should be injecting the fuel. How can they not figure it out?
