Looking for info on airbags or leaf spring helpers
300000 and counting
Ohio
I tow just about every weekend and they are usually pretty decent sized loads, which I think suspension isn't heavy enough for. Usually when loaded I have about an inch of travel before the bump stops hit, I was thinking of replacing the factory helper with airbags which would have to be wirelessy controlled or replacing it with a leaf pack with maybe 3 springs instead of just one. I like the idea of the added leaf because nothing can go wrong and it's A LOT cheaper, but I hear the airbags give you a nice ride and I like the fact that it's an adjustable system. What are you guys thoughts? And if like to see some pictures of your setups.
A little back ground to, my truck is a f350 it has 5" PMF blocks with the bump tag, 3/4" u-bolts, and a B&W turnover hitch in the bed.
The leaf P&J would look like this
300000 and counting
Ohio
Does it hurt the ride quality at all? Being that the helpers hit sooner. I think I would rather ad something extra.
Also for guys commenting I had timberline so that's is out.
2006.1f250
DFW
Yes it does. I pull them out when I'm unloaded. It doesn't take long to remove the uppers and disengage the lowers. Will be loading the camper up this weekend and just using the bags. I want to see how the truck does with only bag use.
FlatbedCowboy
Air bags is the only way to go. I haven't got any yet but that's what im saving for. There are several manufacturers.
You can get just the bags and mounts and manually inflate and deflate them, then save up and get an onboard aircompressor. Then you can get a deal that splits the lines and you can inflate or deflate each side individually. For me I am thinking all I really need is the manual adjust ones, but the onboard air would be nice.
Im thinking about Firestone bags myself.
gnxtc2
Bergen County, NJ USA
I have a B&W GN Turnover Ball with Firestone Airbags controlled with the Airlift Wireless Airbag controller.
The Wireless Controller is the way to go. Prior to getting the wireless controller, I manually filled the bags....PITA. Got the wireless controller, came with a small compressor which inflates/deflates the bags as needed. With the trailer hooked up, I program it to 85 lbs and empty to 5lbs. The airbags take the "snap" when you hit a bump/expansion joint.
I have 5" traction blocks. Rear springs are SD "C" codes which are from a dually.
Billy T.
[email protected]
bigrpowr
<How I Fly
Administrator
sold some firestone's today. let me know if i can help. have some on my green 6.4 and love them .
tbsimmons
Bakersfield, CA
I have air bags in the dually and they work great. I used the normal gauges mounted that I took apart and mounted into the dash to the left of the cluster. I would add an air chuck to air up tires and such, has come in handy. Works great.
Compressor, upgrade to a minimum 5 gal tank and you are good to go.
300000 and counting
Ohio
I called about air bags from my local truck parts place and the want $369 for Firestone bags and $369 for the airlift wireless system. I feel like there has to be a better way and not spend $740
300000 and counting
Ohio
Billy T.
[email protected]
Are there just two settings? Stock and loaded? Also are those just the universal bag or are the made for that truck?
gnxtc2
There are two preset settings which the user programs. You can set the air pressure from 5lbs-100lbs. I use one pre-setting for empty (5lbs) and the other for loaded (85lbs). The 5lb setting is the minimum pressure recommended by Firestone.
Made for the truck.
Billy T.
[email protected]
the actual kit for my setup is like 150 bucks.. i have 90ish into mine.
I no they are cheaper but I really don't like them, they came on my old truck and it rose extremely ruff, when I took the out it helped the ride quality a lot.
these are softer then the timbrens and i have a inch of room before they hit.. but i hear man.. just a cheaper alternative to me..
