Looking for the radiator/transmission fittings, mine are leaking
MrOneEyedBoh
I need two of those fittings for the transmission lines that go into the radiator. Mine are leaking where the line goes in, not the threads.
G Racing
Southeast Texas
Most of the time when you unscrew the fitting you will break the seal on the trans oil cooler inside the radiator and it will mix coolant and trans fluid.
MrOneEyedBoh
The mishimoto's radiator/trans cooler is welded on the outside. Thus keeping the trans cooler in place.
It's leaking where the lines goes into the push fitting. I've wiped it down, went for a ride and its still weaping
Bigger Hammer
Funny, just posted this on another forum you posted on, seems like finding replacements for these is a common problem...
Dorman 800-617 fittings are ~16.00 dollars on Amazon, and are visually & functionally identical to the factory connectors. Dorman doesn't list Powerstrokes as an application, but I replaced the factory fittings on my 2005 6.0 Excursion with these a few months back, and they have performed flawlessly.
