gnxtc2
Towing my GN trailer weighing approximately 22k-23k from Northern NJ to Bowling Green, KY. While pulling a hill on the PA Turnpike, the CEL comes on and loose power. Got a P1211 code using my ScanGauge. While pulling the hill, the motor got a little hot. The coolant temp needle got to the "M" during the hill climb.
I pull into a rest stop and cleared the code. When I cleared the code, I heard the motor smooth out. As soon as I start driving again, the CEL comes back on. I continued driving. I have no power to pull the hills.
Prior to the CEL coming on the second time, the DC shot up to 90% then CEL tripped. ICP would barely get to 1600. As I continued driving, the ICP began to drop down to 1100.
I got off the PA Turnpike onto 70 West and began to climb the hill, Rt 470 (bypass for Wheeling, WV). As I'm cresting the hill, I was in first gear. The motor had no power what so ever.
I pull into the first stop in OH. I clear the code and I pop the hood and check the ICP & IPR sensors. The both checked fine. While checking the sensors I moved the harness for the IPR. I start driving, CEL comes on again.
Then all off sudden, I get ICP back and full power. I continued onto KY with no issues. I shut the motor off while refueling, the CEL cleared and it started right up.
I never shut off the motor any time the CEL was on fearing that I might never get the motor started again and leaving me stranded.
I get to my destination and check over the engine harness in the valley fearing that I possibly melted a wire when the motor got hot. Found nothing wrong. Just to make sure, I re-wired the wiring for ICP & IPR. There was no oil in the ICP sensor.
I need to get back home (850 miles) and don't want to loose the ICP again.
Is there anything I can do or check out?
Thanks
Billy T.
[email protected]
Thanks
Billy T.
[email protected]
