NRHX2009
FOR SALE:
1. Good slightly used Bullseye Power S475 Billet wheel, race cover, 87 mm turbine wheel, T4 1.10 A/R Comes with downpipe flange and clamp and also compressor flange and clamp -------$1600
2. Borg Warner PN: 171702 Rebuilt S475 with new cast comp wheel. 96x88mm exhaust wheel with a 1.32 A/R T6 housing. --- $570
3. Borg Warner S310G Caterpillar turbo. Came off generator, maybe 5 min of run time. 63mm x 92mm Billet Titanium Compressor wheel with Extended Tip, 80 x 73mm turbine wheel 1.10 A/R T6 exhaust housing. Exhaust downpipe connection will need to have a V-band ring welded on to connect downpipe. Has 5" compressor inlet, standard Borg warner outlet flange. -- $650
4. Holset HX-83 NEW 98mm Billet Titanium Compressor wheel. F-trim turbine wheel (106mm exducer) 28cm T-6 exhaust housing 6" downpipe discharge.
----$3000.00
5. Holset HX-82 NEW 100mm compressor wheel inducer, G-trim turbine wheel (113mm exducer) on a 41cm Butterfly flange exhaust housing. $2100
6. Holset HC5A Reman, 98mm Compressor inducer, F-trim turbine wheel, (106mm exducer) 48cm T-6 Exhaust housing. $1900
7. Like new Borg Warner S400-S008 68mm Compressor inducer, Not extended tip wheel, 91x81mm turbine wheel, 1.58 A/R T-6 exhaust housing. Standard borg warner compressor outlet with 5" intake. -- $530
8. Stock Rebuilt late 99-03 7.3L Powerstroke GTP-38 turbo. $550
9. Rebuilt late 99-03 7.3L Turbo with wicked wheel GTP-38. $600
10. Stock Rebuilt Early 99 7.3L Van turbo $550
11. Stock Rebuilt Early 99 7.3L F-series turbo $550
12. Reman H2C 58mm inducer 19cm T4I foot. 77mm turbine wheel $575
13. Like NEW Bullesye Power Race Cover for S475. Has V-band flange on discharge. $350
ALL PRICES ARE SLIGHTLY NEGOTIABLE BUT PLEASE NO LOW BALL OFFERS.
PLEASE CONTACT ME FOR MORE DETAILED PICTURES OF THE TURBO YOU ARE INTERSTED IN.
Many other parts available for S400's and All years of 7.3L turbos.
PM, E-mail or call [email protected] or 717-919-7423
----$3000.00
