Fordcowboy
My truck will usually make a bit of a mOaning sound if you are sitting still and turn the wheel, not bad but you can hear it. Also if you are stopped and push harder on the brakes I will normally get a bit of a moan, and in both instances you can hear it just puts a little more strain on the motor, very slight, I always figured this to be normal.
Yesterday I noticed the moan from the brakes and powerstering was a lot worse. Painful sounding. I checked fluids and they are good. I first heard it with the steering so I was thinking the pump, but having it also with the brakes has me a bit confused. Listening under the hood while someone turned and pushed the brakes it sounded like it was coming from the PS pump or alternator. It seems more like it's just the little bit extra draw on the motor causing the sound. Oh and sometimes it will quit and go back to normal after 10 min of driving. But then might or might not come back if I shut it off and restart in a few minutes. I haven't torn into it yet, thought I would see if anyone had run into this befor and get some ideas first.
