Low a/c fan speeds not working?
thedudebrah
08 F350 XL. Since I bought it, settings 1 and 2 on the fan have not worked when "max a/c" is on. They work when I just have the vent on, but only blow cool air when the truck is moving. Anyone ever heard of this before? Anyone know how to fix it?
Big Angry Hillbilly
Blower resistor most likely.
Mine just quit on '2' this week. Been not working on '1' for a while. Looks like its time to change it out lol.
Atsah
Maine
So your saying 1 and 2 work when just AC is on but don't when MAX AC is on?
As said above, I would say your resistor is gone but 1 and 2 would not work wether it was on MAX AC, regular AC, fan or heat if that was your issue..
WoodBoy
Alabama
Yeah I would start with the resistor too but like atsah I have never heard of it working and not at the same time
thedudebrah
Correct. When the MAX AC is on, I also can't turn off the AC and recirculate buttons, but I just assumed this was normal? It hasn't bugged me too much so I haven't dug into it too far.
When the regular vent/ac is on, if I press the recirculate button, nothing comes out of the vents.
I'll try the heat out tonight, it's been kinda hot here so I haven't bothered trying it.
Atsah
Maine
MAX AC recirulates the inside air so you can't shut the recirulate off when MAX is on.. Interesting.. My 2012 is probably the same, I'll go check it in a little bit to see what mine does... I'm thinking maybe you have a problem with control unit but IDK..
Atsah
Maine
Okay on my truck, you "can" turn recirulate with regular AC so there is something screwed up there.. My guess would be you have maybe a blend door issue or maybe a head unit issue and I would guess the resistor is not right so If it were me I would swap out the resistor first and see what happens.. I don't know enough about the unit iteself to help much, maybe someone else with an 08-10 year truck can help..
