Low boost and smokey
a_moore
Blowing in the wind
running the mild H&S towing. I turned the low boost fueling all the way to zero and it is still smokey/hazey.
Boost towing mountians today never passed 32psi in od or down in drive.
I guess it could be small leak in drive or charge air systems? The low to high pressure crossover pipe was loose a while back causing the lp charger to leak, this was due to Ford not installing the nut to valve cover bolt and it pushed apart. Was this enough to overspin the lp charger?
What is normal boost for the mild, wild and hot tunes latest updates installed.
Thanks
