Low Boost Fuel Setting Questions
Central Illinois
What is the best and safest overall low boost fuel setting I should be running? Ive been running mine on the default setting on my H&S mini max (canned H&S tunes) which I am told is LBF setting number 3. My truck is a 2011, stock turbo, with all the deletes. With a stock turbo, should I just be set it to the stock low boost fuel setting vs the default 3 setting?
I am going to be gettin MCC with Gearhead tunes soon also. When exporting the file from your Mini Maxx, it looks like you have to still select low boost fueling. If Im sending him tunes to make them custom, does it matter which low boost fuel setting I would select at that point? If it does, which one should be selected? Thanks for the help guys!
Dzchey21
wyoming
I have found that 0 is just fine, but im at high altitude. Just play with it and see what you like
