RedSmokey
So my 2001 is low on power. Very low. Not sure what the deal is. Right now Im not feeling safe getting on the freeway as it takes a while to get up to cruising speed. I think its a fuel issue so that is what I will be checking out first, I just wanted to see if anyone else has any ideas? Reason I say I think its fuel, is there are no other symptoms besides it being low on power. The EGT's are low and boost is normal. All guages look normal. I questioned if it was the pedal, but when its floored it will hold the gear till 3k rpms and shift if I let off like normal. The trans isnt running hot either. I am lost. Im going to check the fuel filter first, maybe its getting clogged? If I dont find anything with that, im going to swap out the fuel pump. After that I am really at a loss. Any help and other idea's are appreciated.
