Low tire pressure light on.
El-Magico
Fort Worth TX
I recently replaced my tires went with the 37x12.5x20 Nitto.
Had the 35x12.5x20 procomps.
I didn't have any problems with the old tires. But now the tire pressure light comes on every time I turn the truck on. I check the pressure several times now and it the light still won't go away. I even took it back to the tire shop and had the check n verify the pressure for me. Still no good. I'm down at the ford house and they can't figure why the light is still on. A tech here has the same set up on his truck n he tells me he has no problems with his.
Anybody else have this problem with there aftermarket wheels n tires??
Sent from my DROID RAZR using Tapatalk
Crazy Canuck
Central Canada
What pressures are you running? I know there is a way for us to select what pressure we want them to alarm at also if one is damaged and not sending a signal to the truck it will be in alarm as well.
Ryan2012F350
Alberta
If your running big tires you don't want enough PSI in them to turn sensors off, your tires will cup and wear ****ty. H&S Mini maxx it up and turn those off!!
Dzchey21
wyoming
the dealer can adjust the pressure limit, you also need to make sure that you did the reprogram for them sensors as well.
