Twan
I have a 2006 with 155/30% injectors a powermax full 4" and a S&B air intake. I pull a 40' 5th wheel that is around 16-18k and my egts are around 1200+ if i hit a hill i have a hard time keeping temps down, i see a max of 25psi and water and oil temps climb fast to, got a new oil cooler a week ago, i was seeing 220 water, 235 oil, 1300 egts, and 15psi, it was a 6% grade and i was running 30 mph. The turbo is slow to spool, is there really a way to lower all my temps and get the turbo to light faster. I dont want to wast a lot of money and be in the same boat. if it cant be down then i can spend it on a new truck. Running 70 mph i can hit 1400+ in scounds. I dont want to be spraying watermeth. I live at 4500' and camp at 8000' so the air is thin.
Thanks for any help you can give.
