Lowering F350 SRW suggestions?
BFinMO
NW-CO
Considering pulling the Icon and putting in F250 blocks to level, Anyone have experience good or bad with this?
I assume hardware wise one would need: 250 blocks, shocks, and 250 sway bar end links. My cautions are if the change in drive line angle would be enough to cause damaging conditions.
Any thoughts?
BFinMO
NW-CO
I would be fine with trading rear blocks and U-Bolts if someone wants to. Or, I will be selling my ICON Stage I leveling kit and adjustable trac bar (w/ upgraded end).
Ideally I will find a 250 owner that wants to swap all parts as I have the snow plow prep front springs.
highdrum
If you run the stock F250 rear suspension with the stock F350 snow plow prep springs, you will be almost level. My truck was about 3/4" lower than the front with that exact setup, I think all the snow plow prep springs are the same, spring code BB and rated at 6500 lbs.
RedRice589
Ocala, Florida
You have a p'm
highdrum
Edit to my previous post, the snow plow front springs are CC 6000 lbs to what I just read.
BFinMO
NW-CO
Is there any truth to thinking the plow prep spring will sit a smidge higher and/or have a harsher ride than standard springs?
I didnt notice a huge improvement after the Icon was installed. Not a beef just observation.
