MDP upgrade Fuel Line feed
Pizza pig
MD
Its just going to free up some flow from the stock fuel pump to the fuel bowl. It probably wont help that much, but its a cool cheap option for guys that have the fuel bowl still and a somewhat modified fuel system or slightly modified injectors, every little bit helps the stock supply system
Mdub707
Mohawk NY
Seems like it could be more harmful than good, if your pump is already having problems supplying enough pressure and/or volume to injectors, this line might make it worse, since you've effectively given it a larger volume to hold the same pressure. Though, if the stock line is so small that it's restrictive, it could help. Someone needs to crunch some numbers on that. I'm too hungover to even think about this right now.
Pizza pig
MD
the stock feed line I think is 5/16, and all the bends are crushed.. LOL
