megasquirt 2
kadeninabnitt
Martinsville, IN
Bought me a new beater and was reasearching tuning options and ran accross megasquirt. began wondering if it could be used on a 7.3. did some searching and found one thread on the subject from back in 06 or 2010 that didnt give much info. just curious if it would be a viable option or if anyone has tried it?
mustube
Austin, Tx
It is a pretty cool read.
The transducer makes it to big and I bet it would hit the rocker arms.
Sent from my XT1058 using Tapatalk
jngreen
IN
I wonder if that makes a 6.4 swap more possible
I'm guessing that is what makes a common rail conversion possible on a 7.3. I suppose you could also swap in a 6.4 and run it from 7.3 electronics in the same way, but I don't know many 7.3 owners who would do that.
ja_cain
I'm wondering if they make or can make the transducer with different dimensions.
m j
BC Canada Eh!
the thread in the other forum has some discussion on pressure transducer/glow plugs from a VW so you can monitor cylinder pressure
78f100
Bonifay FL
Last year at TS swamps had a standalone PCM for a 6.4 mounted in a idm case. They said they were working on it and was planning to use a megasquirt to tune it. I haven't heard anymore about it but hopefully it works out.
