Midrange Hesitation
DevC
BC, Canada
Mods done
-Diy e-fuel w superduty pump and tightwad regulator.
-6 pos chip I forget what brand, came with truck
-3in dp, 4in exhaust
-6637 intake
-Single mass flywheel
Recent work done
-Glow plugs
-Injector seals
-Ipr rebuild
-Rotella 15w40 oil
-Blow by does not lift cap
-Swapped crank sensor with spare.
-Unplugged each injector separately with engine running, all are functioning, some may be weak though.
What is happening is around 1500-2000 the truck doesn't seem to pull as hard consistently when one of the power tunes is selected. When the stock tune is selected it will fall on its face and puff a cloud of smoke before picking up and going.
Truck idles good, motor vibrates a bit more then other 7.3's I've seen. Starts good, hot and cold and over all runs great.
