Stroked777
On the drive home this morning I noticed my EGTs dropping from 500-550 cruising, down to anywhere between 92-161 degrees. No codes, trucks running fine. Is it a probe going bad, if so how hard is it to change it? Thanks
Careful not to break or strip the sensor. Probably gonna have to get some heat on it and pb blaster and work it back and forth. We had to do heat and blaster when we just took the pyro out of the 6.4 up-pipes and put it in the 6.0 pipes to run 6.0 manifolds on the 6.4. Just be careful. Since you have a bad probe might be worth using a socket and cutting the wires off to get the old one out.
it's the temp probe in the up pipe
my F350 is starting to flake the probe![]()
Napa probably doesn't even carry it, but if they did, I'd just buy it from Ford. There are lots of places where you can buy OEM Ford parts at wholesale.
I got mine from ford. But be prepared, I broke the sensor off in my up pipe and had to remove it to drill it out, turned a 15 min job in to a few hour job, had to remove the down pipe (thank god for a two piece after market one) to get the up pipe out
