Mishimoto Coolant Filtration Development!
Mishimoto
Hey guys,
We have been working on a coolant filtration system for the 6.4L. Check out the progress on our blog or posted below within this thread.
http://engineering.mishimoto.com/category/ford-6-4l-powerstroke-coolant-filtration-kit-2008-2010/
Feel free to chime in with any comments, questions, or suggestions!
Filtering Your 6.4L Coolant, Part 1: Initial Prototype
We mentioned in our 6.0L coolant filtration thread that we would be tackling the 6.4L as well. Let’s take a look at some of the components our team has been putting together for the 6.4L kit.
Although the 6.4L does not seem to be as susceptible to buildups as is the 6.0L, a coolant filtration setup is certainly still a worthy investment in preventive maintenance.
So let’s get started!
Filter Housing
We’ll start with the filter housing. As mentioned in our 6.0L thread, we developed a housing with a wide range of adjustability that could be utilized for a variety of kits. This housing is shown below.
Mishimoto coolant filtration housing
Here’s a look at the hardware and filter mounted to this housing.
Mishimoto coolant filtration housing and Wix filter
Since we had our housing already, this project should move along relatively quickly. We would need to develop a mounting bracket and run some coolant lines for this kit.
Bracket Development
After evaluating the vehicle, our engineering team determined that the ideal location for our kit would be along the passenger-side frame rail. As you probably know, the 6.4L engine bay is rather tight and real estate is hard to come by. To make servicing easier, and to allow space for performance upgrades, we would be mounting this kit under the vehicle.
We changed our developmental process with this one a bit. Instead of making a fabricated prototype first and then modeling it in 3D, we did the opposite. Dimensions were gathered from the truck and a design was made. We then used a flat-pack printout to create a fabricated component. Check it out!
Prototype bracket drawing
Prototype bracket test fitting
We installed the filter housing and filter to check clearances and ensure our outlets would work with this location.
Now that we had a functional bracket, we decided to spend a little time determining the style. We modeled a few designs of the the bracket and then put a post on the forums to get opinions from the folks who would be interested in such a kit.
The design ideas we had in mind are shown below.
Prototype bracket X-design
Prototype bracket 6.4L design
After running a poll on the forums for quite some time, we ended up with essentially a 50/50 split. We decided to move forward with the more subtle X design.
Prototype bracket 6.4L X-design
Check back with us next time for a look at our final prototype, the test fitting of that component, and the plans we have for routing the hoses.
Thanks for reading!
TRUBBS
Balls Deep
What's price looking like? I need one & was considering building my own, but depending on cost I might be in to order one!
I'll efen test a prototype for Ya ;)
shmoozer
I pre ordered a 6.0 kit and paid right around 125 I believe.
-KCCO-
Mishimoto
Thanks for the interest! Pricing is not yet finalized for this particular kit. It is very likely that we will be launching a discounted pre-sale soon for forum members!
-KCCO-
Thanks for picking up our 6.0L kit!
Wonder if they're going to do a PreOrder on these 6.4 kits also?
Thanks! It is very likely that we will launch a pre-sale for this kit as well. We should have some additional details next week!
Thanks guys!
-John
Mishimoto
Time for an update! Check it out below.
Filtering Your 6.4L Coolant, Part 2: Final Prototype and Installation
Final Prototype Bracket
Welcome back! Our final bracket prototype is in and ready for installation. Check it out!
Mishimoto 6.4L coolant filter bracket
This bracket is constructed from 1/8” steel and is powder coated for additional protection against damage from road debris. We overbuilt this unit to ensure longevity and optimal resistance against potential damage.
Check out the hardware we will be using to attach our housing to the bracket. This hardware is also powder coated to prevent corrosion.
Coolant filtration kit hardware
Next, we assembled our filter housing, filter, and bracket together.
Coolant filtration kit assembled
We then installed this system to ensure fitment on our test vehicle.
Coolant filtration kit installed
As you can see, we are using ball valves at the hose connection point to our filter housing. By shutting these valves, one can perform filter changes without draining a substantial amount of fluid. Here is a closer look!
Valve
We are also utilizing silicone lines to route coolant from the heater hose to our filtration system, and then back to the degas port. Check out the route of these lines.
Coolant filtration hose routing
Once installed, the primary components of this kit are hidden from view. Here is what you will see once this kit is in place.
Coolant filtration system installed
As with our other kits, this will be offered with your choice of black, blue, or red silicone hoses.
And that’s it, the project is complete. Check out a shot of all components included in this kit!
Coolant filtration system components
Thanks for following along with our development progress. For those interested in picking up this kit, we will be launching a discounted pre-sale next week!
Thanks
Mishimoto
For those interested in picking this kit up at a discounted rate, check out our pre-sale details below!
Pre-Sale Link
Price: $140
Launch Date: 2/12
Estimated End Date: 2/20
Estimated Ship Date: 2/22
Product Specs
  • Direct fit for the 2008–2010 Ford 6.4L Powerstroke
  • Filters solid particles from your trucks coolant
  • Installs in under 45 minutes
  • 6061 anodized aluminum filter mount
  • Includes Wix coolant filter
  • Extends the life of your oil cooler, water pump, EGR cooler, coolant, and other critical components
  • Ball valve shut-offs included
  • Available with black, blue, or red silicone hoses
  • Includes all components necessary for installation
  • Mishimoto Lifetime Warranty
Tech Specs
Images
Pre-Sale Link
Feel free to follow-up with any questions about our kit!
Thanks
-John
Mishimoto
Hey guys,
Just chiming in here to provide an update on this product! We noted above that our pre-sale units would be shipping around 2/22. Unfortunately we've experienced a few shipping delays which pushed back this date. We finally received these kits in our warehouse and shipped out our pre-sale units earlier this week. Those involved in the pre-sale should have received tracking information.
If you did not receive an email, shoot us a PM so we can take a look at your order!
Sorry for the delay!
-John
Mishimoto
This kit has officially hit shelves! Check out the details below!
Ford 6.4L Powerstroke Coolant Filter Kit, 2008-2010
Product Specs
Tech Specs
Features & Benefits
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Installation Guide
YouTube Video
Product Development
Ford 6.4L Powerstroke Coolant Filtration Kit 2008-2010 | Mishimoto Engineering Blog
Images
Feel free to follow-up with any questions or comments!
Thanks
-John
