madpowerstroke
OK first post as vendor, I just got done going to Atlanta, and delivered my first stage 4 to leadfoot performance. Johnanath is going to put it on this truck and rip it up. He's running 285cc injectors full built engine and transmission. He plans on getting it live tune on Sat. so I may have dyno numbers, and yes he will take it down the track for track times. I have my fingers crossed, I hope turbo performs. The turbo measures 70.8mm/96mm compressor, I belive it is the biggest VGT turbo to ever go on a powerstroke.
If I'm wrong tell me, this turbo is fully drop in replacement factory turbo, as are all the turbos I build. You don't need anything extra, bolts to factory pedestal, and hooks up like stock. I also have a stage 3 that is being live tuned on Sat. at IDP by Eric. I will have dyno numbers on that one too, and track times, since he also has a built tranny. By the way he ran the track, with a powermax 68mm tune untill he could get it live tune, 8000lbs truck weight at the scales and ran a 12.5 @ 106mph. Do the numbers 650rwhp with stock intake manifold, heads, exhaust manifolds, and 190/100 fuel injectors.
Before I get the nah saying, he will have dyno results and back it up on the track. I believe with a live tune he might hit higher than 650rwhp.
Thanks, Adrian
Thanks, Adrian
