my mad turbo stage 1 review
04redcrew
mt vernon indiana
Heys guys
I just got my Adrain(madpowerstroke)turbo installed on Friday. So bare with me this is my review so far.
So the day I started it up I said wow this is quite compared to my 03 turbo, I pulled out of the shop drive way and to myself the pedal is more toucher and not a bad thing. So I drove around a little bit and said to myself(again) I don't see much difference but in the drivability besides the pedal. I wasn't impressed that much, so it was parked for the night.
So today has arrived and I get in the truck and get going and i said, now I can start to feel that the turbo is starting to learn like Adrian said it would. I started driving and I said wow very easy pedal for easy boost(nice). Drove to Evansville maybe 20 miles of non stop driving, egts were around 650 at 65 with the outside temp of 95+.
So I finally get back to town where I could get on it where it gets more powerful than the first day. First time I got on it I watched the tach and speedo, and speedo climbed fast. So next run I watched my egts and smoke, let me remind you it was 95+ out today plus humidity , so when I got on it going all the way to 80mph it hit 1400egts. I didn't think that was bad at all do to the outside temp and humility. So now onto the smoke, I floored it and it shot out a nice haze(kind of black) but cleared up to a haze under wot(under wide open throttle). It would clear up completely around 2700k than shift when it needed to and go back to a haze. I don't think there is anything wrong with the haze And i think it should get better as I drive it more.
So far I'm very happy with the turbo, I can't wait till it has relearned itself with my truck it should be a nice upgrade to what I was running.
I hope this feed back helps you guys and I will continue to report on it.
I do have one question though. My vgt% is 5-7% lower than the 03 turbo. Is my vgt sensor going bad or do you think its the difference in the turbos?
Thanks guys brad
imelmo
What injectors? And what is learning? Hadn't heard of that before for swapping turbos.
Pizza pig
MD
vgt relearn only really belongs on 03-04 trucks, from what i've seen at least
madpowerstroke
Mississippi
The relearning is the PCM taking in all the new numbers air coming in and the map sensor,and so on.The truck actually starts to learn what the turbo is doing now and recalibrates it's self.The truck actually starts to run stronger and stronger as it learns.Weird isn't or just MAD.
04redcrew
mt vernon indiana
i havent dynoed it but a guy running the same turbo on 35s made 475.
I was running the srl+ and i just loaded extreme srl will see how it does with this tune.
04redcrew
mt vernon indiana
almost ran a tank of fuel threw it. Wasnt that greatest lol because my foot has been in it alot. I can maybe get a video for you guys over the weekend, we are busy in the fields right now
