Need 7.3 oil cooler part and help
Magnum PD
VA
Was putting the oil cooler on the engine and there is bypass assembly that goes into the rear adapter housing. I tried putting the cooler on the block but the bypass wasn't in the adapter right. Tighten the bolts up, and CRACK broke the rear housing. :fustrate::fustrate:
So,.... I need a new rear housing and the right way the bypass assembly goes in.
David N
Eastern NC
I think I have one? Its a used one, and its sat in the rain for a couple months now. I can check when I get home friday if you want me to. Pay the shipping and you can have it.
