Need a little trans help...
josh6420
Recently my trans has developed a hard shift from 2-3. Doesn't do it all the time though. Scanned with Modus and couldn't find any trans codes. From what I was able to read using the "search" and good 'ol Google led me to believe a valve body might solve my problem. I have a feeling something for the 2-3 shift is sticking...The other shifts are fine, if anything a little soft (to be expected on a transmission with 220k miles). Truck is in stock configuration and has had a tuner on it in the past, doesn't now.
All this to say, has anyone had similar issues and did a valve body replacement help? Trying to get an idea before I shell out money for a part that "might" fix my problem.
Any help would be greatly appreciated! Thanks in advance.
fastersteve
I had one do this.
Some times it would bang so hard it would rattle your teeth, other times smooth as stock.
Turned out to be a broken spring in the valve body.
TransGo tugger kit cured it.
