Need a set of heads
jensen508
Shelton, NE
Hi im new on here and looking for a good set of heads for my 05 6.0.
Any help is greatly appreciated.
Sent from my DROID RAZR using Tapatalk 2
jensen508
Shelton, NE
Thats what i wanna do but im on a tight budget. I am a toolmaker and can do all of the machine work on a set of used one myself.
G Racing
Southeast Texas
The injector o-ring and the injector cup would both have to fail to get fuel in the coolant that way. The lower injector o-ring sits just above the injector cup unlike the 7.3 more than likely you have a crack in the fuel rail. You can pull the injectors and pressurize the cooling system looking for the leak or you can pull the heads and pressure check the fuel rail. I'm still going to say you will have a cracked head.
