Need elp with gauge wireing
hunter scar
Hello everyone im putting a set of Isaapro ev2 boost and pyro in. I have everything done but the wiring. I spliced into the Blue wire with black trace as shown in the diesel manor instructions for ignition source. Then I spliced into the light blue wire with red in the back of the dimmer switch for illumination. Then i grounded it with a bolt. Im using the harness for the gauges. I just plugged the gauge in to see if things were working. But for some reason i have no lights or anything working on the gauge. I checked the red ignition wire at the clip that goes into the gauge and it only had 6 volts. Then the interior lights would not go off so i disconnected the red wire i had spliced into the ignition and i went off. If anyone has some advice i would appreciate it thanks Hunter
JLDickmon
I'd have to say you're not in the right wire.. sounds like you're in the "fade out" wire..
hunter scar
Ok thanks for the info i tried one other splice and could not get no power off it. I went and bought a add circuit and found a 10 amp fuse with key on power. You think that will work? Its fuse 45 for the ignition switch run/ start feed
