Steelnc
I'm hoping you guys can help me decide on which to go with. I was set on the 175's but i only plan on doing this once and wanna make sure i make the right decision. My truck is a daily driver and i do occasionally tow around 6k with it. (6x12 utility trailer full of tools). Anyway, i'm looking to top out around 550 hp (eventually) and i'm done. I know i'll need a r.r. which i plan on doing the same time to keep the injectors running safely. However, the turbo upgrade is most likely gonna have to wait a few more months. Is there that much of a difference between the 175's and the 190's? Can i tow safely with the 190's? I'm assuming both are gonna smoke with a stock turbo depending on how i drive. Pros/cons. Mods are in my sig. Also, i was leaning toward a PM with the batmo but now i might save up for the Rcd 68. I'm hoping i don't end up having to buy a new trans with either of these setups. (wife will probably remove my balls with her teeth if this happens) Thoughts from guys running these setups? Thanks.
