need help asap!a!
smokedout250
harrisburg oregon
Ok so installed my t500 now my guages on the dash quit working ... when the fuse blows for the guages I lose power in my truck almost like my pump is turned down
zilla68
Moore Oklahoma
you had to have left something either unplugged or hooked up wrong electrically. I can't imagine the hpop would affect fuses.
Tom S
Which fuse blows and did you do any work other then in the engine valley?
Tom S
Fuse 17 runs Diesel Warning Lamps, Instrument Cluster, Warning Chime Module, Trans (OD) Control Switch, , Water in fuel Switch, Low Vacuum Switch..
The most obvious ones to me would be the Water in Fuel circuit first, Low Vacuum second, and chaffed wires on the TCS last.
