Need help, no start, no rail pressure
dohcter
Hey Psa, I need some help. I purchased a complete used engine, got it put in, but cannot get any rail pressure. I've bled the system, using Ids to turn on the lp pump, cracking both lines on the fuel cooler. Have great flow there, but rail pressure only shows ~23 psi. Took the hp line off at the left head and no fuel when cranking. What am I missing? No codes other then low icp while gm ranking. Thanks
dohcter
Got it, disabled the glow plugs and ran it off starting fluid for a min and it took right off. Thanks psa
dohcter
Don't know for sure, but I'm thinking more along the lines of more rpm to clear the air out of the system
Stroked777
Casper, Wyoming
I know it's a different beast but we had to do that to a 6.0 at our shop to get all the air out. Just ran it on ether for 15-30 seconds and then it stayed running on it's own
