Need help. Sct problem after non vgt conversion
dohcter
Hey guys need some input on trouble I'm having. If you seem my other thread I'm working on compounds for this truck. Have it all out together but when it's programmed , key on engine off the injectors will never stopped cycling. Strart the truck and ot runs just like ite just cycling the injectors with the koeo. Reprogram to stock it's fine. Had Eric redue my tunes with no change, canned tunes act the same as well. Have tried addin grounds, plugged in the vgt solenoi, egr valve, etc. no change.
Truck
2004.5
Deleted egr
Studs
New ficm
Sct with tunes from innovative
Bd thruster turbo over s478
Warren 155/30s
Tune ear is a original live wire 9600 with latest firmware and was formatted this morning.
Any ideas? Thanks
hawgdoctor
king george, va.
Have you tried re-loading the file to your live wire? Almost sounds like something got corrupted in the file load since it does fine in the stock file.
dohcter
Got it, here's one for the record books. It was a bad connection at the eot sensor. Looked plugged it but wasn't making a connection. Fixed that and koeo ficm cycled like its Spose to.
