Leaking fluid from where the line goes into the caliper. Any ideas?
Jun 15, 2013 #1 B bpb424 New member Joined Jun 16, 2011 Messages 390 Reaction score 0 Location Chillicothe, OH Leaking fluid from where the line goes into the caliper. Any ideas?
Jun 15, 2013 #2 neverkickn New member Joined May 22, 2011 Messages 2,692 Reaction score 0 Location AR copper washers or bad brake line.
Jun 15, 2013 #3 H Highroller54 Member Joined Mar 23, 2013 Messages 341 Reaction score 0 Or loose banjo bolt
Jun 15, 2013 #5 B bpb424 New member Joined Jun 16, 2011 Messages 390 Reaction score 0 Location Chillicothe, OH Thanks I was afraid the caliper was bad. I cranked down on the banjo bolt a little bit and I'm going to monitor how it does.
Jun 15, 2013 #6 6 6.4stroke Guest if you have a torque wrench handy the torque spec is 26 ft lbs on that bolt
Jun 15, 2013 #7 uga33 New member Joined May 18, 2011 Messages 704 Reaction score 0 Location Cartersville, GA Washers.
