need help with leak..
sc
Hey fellas, saw this piece here i got the pen pointing at on the side of my fuel bowl. Is there an o-ring kit they make for this? figured yall would know the part numbers and all that and what its called.
Thanks.
:biggun:USMC
kadeninabnitt
Martinsville, IN
i believe that is the water in fuel sensor mine leaked so i yanked it and put a brass plug in its place problem solved if i remember right there is no oring
backwoodsboy
Merica
Fuel filter restriction sensor.
Pull it and replace with a 1/8th NPT plug. Don't over-tighten it, the aluminum fuel bowl has a tendency to crack.
