Red_93_L
I got the cab back down and finished tonight after doing a headgasket job, we topped off all the fluids and decided to take it for a spin. After the initial startup whenever I'd go to start, it took about 5 times longer than normal to crank before it started. Then once I got it started it was blowing quite a bit of white smoke out of the exhaust, I didn't think much of it at first. Well when I went to pull out of the driveway it had a pretty noticeable vibration in the engine, so I stopped and popped the hood and pulled the oil fill and it had a ton of blow by and the oil had a definite diesel smell. So my question is where do I start looking for my problem? Is it a leaking fuel line or injector? Any help would be great, I'm at a loss and don't want to go down the wrong path.
