Need some info hope I can get some answers
FlSD
So I was wanting to know if the ring and pinion in a 2000 f350 dually with 4:10 gears will fit into a srw chunk? And info will help before I go spend 300 on a complete drw axle.
FlSD
Thanks Arisley. I'm still new to the powerstroke stuff and wasnt sure thanks again.
FlSD
Ok now I have another question that doesn't concern the rear end, I am getting a E450 ambulance turbo for free it has 60,000 miles or less on it. Will this turbo be a direct bolt on or will it even work if so what will I need to make it worth my while. I have a ww2 sitting in the cab of my truck waiting to be put in what ever turbo (its for the gtp38).
Arisley
Arlington, Texas
If the ambulance is a 7.3 it will bolt right up.
It is the same turbo as yours is.
Sent from my truck while eating, adjusting the radio and passing a Mustang sideways.
FlSD
Ok I was told that if it was the van frontend e450 that it has the gtp38 but the housing is 2"s bigger is that correct
