Figure i'll chime in. I love other people's diy projects to see how they turn out. You could use steel, but with out it being coated, the acid in the exhaust will start eating at it quickly. Cast holds up considerably better in a high heat acid environment. I haven't found a ceramic coating that I'm happy with for sticking to stainless because nothing really wants to stick to stainless, but it could be better with steel. Make your welds all full pen. to hold up to heat cycles. Any weld that is a fillet, needs to be welded on the inside also. Back file welds for stress relief. Have fun you'll be there awhile. I weld stainless pipe for a living and it takes me a considerable amount of time to do a set of manifolds. 52 welds total counting roots and caps seperate. But, they are all top quality welds, no short comings.
