Guys Im needing to find a part bad!!!! I have hit every salvage yard with in a ~100 radius of me and can not find it, was teaching son to drive thought he had it in park and was in reverse and backed into pole:shrug: anyway what Im needing is on a OBS crew cab drives door pannel the section that starts down low and comes up the door flareing out to were the power locks / windows switches are, you can very carefully remove this from the pannel itself Im only needing this plastic part as I have found a shop that can recover it and put it back on the pannel itself very easly so any help would be GREATLY appriciated, or if you have a gray door pannel with power locks and windows......
