Neen help deciding turbo
kdogg85
I'll second the 364, maybe with the fmw as well. I don't think the stock nozzle is enough to be decent with a 366. Or you could look into the 8374 efr, big money though.
OBS F350
Burlington, IA
I put just a regular Powermax on my buddies 03 with 190's/stock and it runs great, the pmax cleans them up pretty well at WOT. I would recommend a Mad stage 1, hybrid, 2 or 3 though, you can get a hybrid for less then a powermax and have twice the turbo.
02POWERSTROKE7.3
Alexandria, IN
Did he run the 190s with the stock turbo?
OBS F350
Burlington, IA
Yep. For about 30k miles then stock turbo had enough. My truck with 190/75's on a stock turbo will pull on his, and he is cc/sb. IDK why but it does LOL. Do you have the injectors already in your truck? You might as well go with a larger nozzle then stock if you haven't had injectors built yet. JMO
kdogg85
In that case, leave it alone then, unless you are willing to keep the throttle under 3/4. Leaving the stock tires will prolong life as well.
With stock nozzles, the 62 or 64 would do better. If you went with 75% nozzles, the 66 would be the better choice, because there would be enough fuel down low to turn it good, and that'll leave some p/w room as well.
