New Ball Joints - What Else?
genie144
Under a Tinfoil Hat
So I have the popping and will be replacing all 4 ball joints. I decided to go with the XRFs. What else should I do at the same time? I am going to be doing rotors, pads, and likely calipers. I would like to do all this at once...
Sam
caladash
In A House
Shocks if your due. They are right there. Maybe service your bearings.
Things I almost forgot, caliper grease,anti squeal stuff, new brake hardware, axle half seal, and the dust seal for the axle tube. nomenclature might be off. just did the same stuff on the excursion.
91turbogsx
Gardner MA
Everytime I do ball joints I always recommend just doing the axle u joints, new hub seals, and axle dust seals at minimum.
