new borgwarner s300sx 9180 t4 divided .91ar
tigwerks
Just like the title states, brand new borg warner turbo. Used only for mockup for some turbo systems i shipped overseas. s300sx 9180 turbo. t4 divided .91ar exhaust housing. $700 shipped
tigwerks
The S300SX 9180 is the byproduct of BorgWarner/Airwerks' engineering efforts to deliver massive boost performance with excellent fitment and value. This turbocharger is one of the highest power and fastest responding turbos that can fit in true street cars with Air-Conditioning. It uses a 7-blade Extended Tip compressor wheel w/ 66mm inducer & 91mm exducer rated at 82lb/min. 4" Ported shroud Inlet, 3" outlet compressor housing. Turbine side is a 80mm inconel turbine wheel which shares blade aero with the EFR family, on a 4340 steel shaft.
copy and pasted from full-race
