next mods for 08 6.4
8luggin
mechanicsville virginia
hey guys unsure on what i should/need to do next as far as mods for reliability for daily driven and track fun.
2008 f350 about 87k on it
afe exhaust with dpf delete
s&b intake
spartan tuner all level licenses
elite egr cooler delete (not installed yet)
WHERE DO I GO FROM THERE
Dzchey21
wyoming
LOL i know the feeling, either way your gambling on both the studs and the transmission as of now, so when you can get them done
jdgleason
Fort Collins, CO
I would definitely look into a ported intake manifold... Ours is a nice piece, and air flow to the rear cylinders is not great with the stocker
oneturboforme
Ported intake manifolds help quite a bit, there suppose to reduice the chances of cracking pistons because the cylinders will breath better ptp sells one also, you could do a cold side pipe and a intake elbow, but like others have said, you trans is just waiting to go specially if your running bigger then stock tires, as far as my truck goes I think ladder bars have been my best improvement, even after I got my trans built it would still shift funky, after the PMF ladder bars it shifted perfect, I'm running 37x22s on stock gearing..
mhop
Holland Michigan
Im a prime example of trans going talking a sh!t on you. i only have an egr delete and an H&S. I also popped the head gasket the same day i blew out my trans.
oneturboforme
Lol good ol diesels, aren't they fun to fix when you rod them... Lol I know the pain. My last dodge spun the bottom end.... Sorry for the derail
