Power Strokes
6.7 Aftermarket
Nitrous on non built motors?
[QUOTE="amplituderacing, post: 1471321, member: 28614"] Nitrous is an oxidizer, but mixed with diesel under pressure it becomes violently combustible. Unless you've designed a way to inject nitrous only on the exhaust stroke in your diesel to lower EGT, it's going to be used as a 'fuel' in the sense that it's going to be injected in the motor along with more actual fuel (diesel) to create a stronger combustion. Is the nitrous really combusting? No. Nitrous is actually non-flammable. But you're using it as a fuel because you're mixing it with diesel in high pressure. Point is ... bigger, faster bang regardless of how you make it = horsepower, and horsepower breaks parts. If these trucks were reliable at 1000hp, they would have been marketed at 1000hp. Inviato dal mio Nexus 6P utilizzando Tapatalk [/QUOTE]
02 F250 7.3 Will crank, WTS stays on, no start, no OBD
Latest: Sterling6.7
Jun 7, 2026
7.3 Tech
P0087
Latest: DEEZUZ
Jun 7, 2026
6.4 Tech & FAQ
2015-2019 6.7 HPFP New In Box
Latest: lincolnlocker
Jun 1, 2026
Engine and Drivetrain
First 6.0L (56k warning)
Latest: adrianspeeder
May 26, 2026
Extra external motor oil cooler?
Latest: justinlogue5_0
May 26, 2026
7.3 Tech
Diesel625
rusty1161
Power Strokes
6.7 Aftermarket
