No crank
BigBluediesel08
Laredo,Tx
Truck sat at home for a day,Tried to crank it tonight, but nothing. Lights and radio work. Batteries and alternator were replaced this past December. Could it be that a battery has gone bad already? Gona connect a battery charger just to rule out the batteries. No codes. Thanks
Spatel23
Olive Branch, MS
Im assuming you have no codes after youve read them with the DD?
Whats FRP with KO EO?
Can you hear the low pressure pump at all?
jdgleason
Fort Collins, CO
JD, you the man! Cleared the codes(didn't show any on the dd) and boom! fired up. That was weird.
I've seen a couple trucks do that before.... Seems like no rhyme or reason for it. Never checked the codes with IDS, so idk what the deal is lol. I just know that there are some codes that even the dashdaq won't pick up.
GROSSpolluter
So Cal
I've had codes on my xrt pro show up but not on the cts. Sometimes mine wouldnt start due to the way my airdog was wired up. I used the relay and junk that came In the kit. So after about the 5th time of no crank I yanked the airdog b.s. out and cut the oem plug wired it direct. Not sure if you have a airdog or not but that could be your problem. After doing that I haven't had it do it since.
