no electrical
powerstroke9608
Montana
Had cab off for some repairs. Hooked everything back up and now have no electrical power to anything. Batteries both have 12.5 volts and all connections are clean. It also seems all the fuses are good. is there any fuse or something that could shut off power to everything. I checked over everything 5 times and all connections are hooked up.
greasltn
Hillsborough, NC
When you connected the driver side battery did you remember the positive wire that feeds the cab? Sometimes when you put the degas bottle back in it will hide the wire from you.
powerstroke9608
Montana
Grounds are all good I removed them all and cleaned them. I guess I'll check for that power wire by the degas bottle and see if I missed it
