Powerstroke Man 6.4
- Joined
- Jan 10, 2012
- Messages
- 4,037
- Reaction score
- 3
Okay I know I got my bronco it has no gears at all if you put in D 2 1 R ill make a wining noise (sometimes) (will rev up like its in neutral) . (no grinding in park). Fluid is bright red at the correct level (not burnt) If you put it in drive the rpms will jump up. But if you put it in 1 (sometimes) i'll drop down like it is engaging. Still no movement though. Whatcha guys think trans gone? transfer case? body has 127,000 original motor blew at 32,000 (in '97) it was replaced by ford. it has a ford remand trans dont know when it it was put in (not original owner). Thanks guys.
