No power power windows
96stroker74
Barclay , Maryland
Anyone fool with the power windows motors .i replaced the motor in the back door and it will barely roll the window . The other door seems weak but it's original
powerlifter405
Butt Town
check the contacts in both switches. I hear if they get dirty, corroded or worn they current drop is enough to cause the problem your having.
Is your regulator/the track "X" system lubed up well. Sometimes the plastic guides break or go dry.
zilla68
Moore Oklahoma
GREASE the tracks, I thought mine were going out, and I cleaned and greased them and they worked like new with out replacing anything!
