No start after cup and injector install
dogdog130
just replaced my cups becouse of bad leak. well replaced all cups and injector from a rolled truck the truck ran when pulled. well installed went to start and have tried for 2 days on and off still not start did buzz test and passed , checked oil reserve and was full any ideas. when i first tried to start it acted like it was hydrolocked and then hit it again and been turning fine
https://youtu.be/WCiDfm9i9rQ
johngaddis
Yeah liquid doesn't compress very well. Could have jumped time maybe.
Sent from my 0PJA2 using Tapatalk
Arisley
Arlington, Texas
If Hydrolock caused it to jump time, you have worse problems than you can even think about. Hydrolock will bend a rod.
ghohouston
Lewisville,Texas
Did you prime the fuel system, and lube the injector o rings when you re installed the injectors? Engine oil level? Uvch's properly together? I have literally never seen someone bend anything on a motor from turning it over while hydrolocked. Is it smart? Hell no, but i have seen it done numerous times with no problems. Could it be cranking too slow?
johngaddis
Also, ohm the injector and make sure, A: it has current B: it is the correct current in range.
