No Start Intermittent ???
ColoradoMO
Colorado
Been having an intermittent no-start, also have an OD OFF light that just started blinking(need to have codes pulled). So while I was removing the OD OFF light wiring in the shifter(to check for worn wiring) and taking the steering column covers off it seems as though the no-start got much worse. Any ideas on what would cause the in the steering column? Truck is an Auto 01 F350 CCLB stock with Swamps tuning.
Thanks
JHILL
NW Oregon
:whs:,
does your shift lever seems off? check the 2 torks head bolts up on the linkage under the dash see if there loose.had a 99 act up intermittently, (no crank) both were loose one almost fell out.
no issues since
