hi
long term lurker but now need help
I've had a few injector problems stemming from inadequate torque. I removed both injectors, re-ringed them..cleaned out the bores, checked to make sure no old copper o rings stayed behind, and re installed.
now, the truck will not start even after being plugged in for 6 hours. i scanned while cranking and had icp of 700 and climbing, cranking speed of 140 rpm.
the tach has been wrapped around to the right and is frozen pointing straight down.
i ohmed the glow plugs through the uvch and had readings from .6 to 1.0 +-.
i had near battery voltage to the harness from the stancor relay.
the truck passes white fuel smoke as it cranks...but no go.
where to i go next? i need this truck to run badly.
