noise in front end
Jassman
MS
I have a 15 F350 LWB with a Pure Perf. 6" suspension from front to back w Fox 2.5 adj. shocks. When I hit the brakes I hear a clicking noise in the front end...I have upgraded the track bar..but they have to keep cranking down on that piece above, or connected too....whats the piece called and how do I go about upgrading this with the best part or parts. Thank You. Jeff
Jomax
Arizona
The trackbar on the frame side or the side connected to the axle using a ball joint?
Welcome backJassman havent seen you for awhile
is it a constant clicking or only a one time thing every time you hit the brakes?
Jassman
MS
Thanks, ya, its been a while. I believe its the pitman arm nut. At least start with that on Monday... Im going to get a new one, locktite it and crank to 380*.
Jomax
Arizona
Use a new pitman arm nut and red loctite.
Also check your radius arm bolts/nuts. They should be at 222ft lbs IIRC.
