Non vgt and electronic monitors
Adamv7010
Once I ditch the vgt and goto a 66 what parameters pertaining to the turbo will still be viewable from my livewire or CTS?
I would assume boost would not be but ebp would Id think.
Thanks
BlueWaffle
Grapevine, TX
you have to take the cts off the truck and plug it into a laptop and program some parameters based on elevation and barometric pressure yada yada yada. there are instructions for custom mapping in the eas manual.
Adamv7010
Any idea how to do it with the live wire 5015?
strokin6L
Springville NY
When I was running my 64mm non vgt I was seeing 45psi of boost from my edge insight CS. Didn't do a darn thing...just changed turbos. Or are you guys talking about ebp?
Cutting-Edge Diesel
Newkirk, OK
I think lance is talking about the eas add on 0-100 psi sensor I got him. Because I don't know anything about reprograming the map
But to answer your question back pressure and boost is not effected. But your factory map probably will max out
BlueWaffle
Grapevine, TX
^^^^ my internet coach is watching out for me. I mentioned eas instruction but but forgot to mention the extra eas sensor. it's part of the expansion pack but once you plug it in you have to pull the CTF off and program the parameters for that sensor
Powerstroked162
On Da Juice
Wa. State
I was gonna say lol. Cinderella was making it up as he went
ncdzl
This makes better sense now Lol
I was trying to figure out how an individual could rewrite coding for a device
