Non Vgt Turbo Oil drain
powerstroke 825
Cape Girardeau Mo
Iam planning on going with a non vgt charger here in the near feature. I plan to use the CED T4 uppipes. So here is my question. What is the best setup for the oil drain as far as making one or kit to buy? I would rather make one being that it would probably be cheaper but i would like to know what all i need to buy as far as AN fittings and lines.
Thanks for the help in advance!
Pizza pig
MD
I usually use a
-10 an male drain fitting (on the bottom of the turbo)
-10 stright push lock fitting off the turbo drain flange
-10 an male aluminum bung welded to the pump cover
-10 an 45* push loc fitting off the pump cover,
connect the two with some push loc hose. I made my own hardline drain tube for my CED pipes.
Cutting-Edge Diesel
Newkirk, OK
Here is a picture of the ready to install kit.
