Noob head stud question.
08Monster
How can you tell if you have head studs? Where do I look? The engine compartment is just such a mess to look around
Sent from my XT1080 using Tapatalk 2
bigrpowr
<How I Fly
Administrator
there are a few bolts outside of the valve cover. if you see hex head bolts, its head bolts, if you see studs with nuts and inset hex pattern inside the end of the bolt, its studs. you can probaly see a few on each side depending on what your engine bay looks like.
Csilva187
Whs^ Passenger side should be easy to see? Driver side is toward firewall?
08Monster
Anyone have a picture by chance?
